1996 Ford F150 cut off when driving
1996 FORD F-150
168,589 MILES • V8 • 4WD • AUTOMATIC
HUNGRYJACK
5.8 /V8 .. I replace the cam shaft sensor.
I replace the throttle position sensor and the Duralast air bypass valve to and the ignition control module to it runs good but when i drive it it still cuts off, I know i need to replace the O2 sensor to ..
Would the transmission do this ? or a sensor if wicths one? I need HELP if you need more can you PLZ call me at 706 681 5393 ,, I talk butter then typing so plz call...
Mar 11, 2010 at 10:26 AM
