1996 Ford F150 Blend door?
1996 FORD F-150
174,000 MILES • 6 CYL • 2WD • MANUAL
JEFFJACKSON
My F150 has a temperature dial which I think opens or adjusts a blend door in the air system??? Anyway when I turn the dial to hot there is a slight resistance like you might expect if the cable behind it was hung on the far end. Is this attached to a blend door as I've been told by some reasonably competent floks or to a valve on the heater coil? How do I solve the problem? Thanks - Jeff Jackson
Oct 1, 2008 at 1:30 PM
