1995 Ford F-150
KSRMSCOX
  • 1995 FORD F-150
Engine Performance problem
1995 Ford F150 V8 Four Wheel Drive Automatic
i replaced my oil sensor and stil have a high oil pressure indication on my ford 150 v8 5.8 winsor engine any ideas as to what might be causing the high pressure also ive changed the oil pressure is still high btw oil is at proper level
Saturday, February 27th, 2010 AT 8:39 PM
  • 109,885 POSTS
There is a pressure release on the oil pump, but if you are not getting disfigured or leaking oil filter, chances are the gauge is bad. Go to a nationally recognized parts store and rent a mechanical oil pressure gauge. Remove the oil sending unit and screw the mechanical one in. See what pressure it reads.
Saturday, February 27th, 2010 AT 10:06 PM
