The ABS warning light is on, brakes seem fine, fluid level is fine. Cannot find a leak. Strangley though I have no brake lights or turn signals, also the cruise control has ceased to function. All symptoms accured, as best I can tell is when the ABS warning light came on. Maybe a two part problem but I do have the marker or running lights still working. I inspected/tested all fuses and wiring on the master cylinder. Need help. THANX.
SPONSORED LINKS
Friday, October 1st, 2010 AT 8:42 AM
