1994 Ford F150 very little heat
1994 FORD F-150
10,000 MILES • V8 • 2WD • AUTOMATIC
SPIDER6
3 thermastates and still very little heat
temp gauge never gose past the (N) in normal on the gauge heater doors open and close fine ther is just enough heat to keep windows clear
but WI winters are very cold need more heat
bought truck in las vegas not as cold there but still had same heat very very little PLEASE HELP
Dec 8, 2008 at 7:36 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Hi:
What temp t-stat are you getting?
Dec 12, 2008 at 3:58 PM
SPIDER6
I have a 195 degree thermastat in it
no air bubble in system . I even place some cardboard in front of rad ans still runs very cool .
Dec 13, 2008 at 3:09 AM
BLACKOP555
  • CERTIFIED EXPERT
  • 10,386 POSTS
thats quite a hot thermostat!
feel your heater core hoses with the engine hot, are they hot? one hot and one warm? both hot? both cold?
Dec 13, 2008 at 9:32 AM
SPIDER6
yep did that one very hot one slightly cooler
Dec 13, 2008 at 1:28 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Hi:
The heater vent door must not be opening far enough. It's a vent that opens and closes allowing heat to enter and it blocks the heat when it's warm. A 195 degree t-stat is the factor temp. That should be working fine for the heater and the engine. If both hoses are hot, that means coolant is passing through the heater core and it should be creating heat. The last thing is the vent door. It should be located in the HVAC ductwork nearest the heater core. I realize you mentioned the heater doors work fine, but that is my best guess based on your descriptions.
Let me know what you find.
Dec 13, 2008 at 1:48 PM
