1994 Ford F-150
L KOPINESS
  • 1994 FORD F-150
  • 6 CYL
  • 33,500 MILES
The brake pedel applies itself on startup I suspect the booster as when I remove the vac line it releases you guys ever heard of a booster working backwards
Thursday, April 1st, 2010 AT 12:50 PM
CARADIODOC
  • 34,358 POSTS
The valve is leaking that lets atmospheric pressure in on the pedal side. You should hear a hiss under the dash by the pedal. This isn't a common failure so a repacement booster from a salvage yard will likely work fine.
Caradiodoc
Wednesday, March 10th, 2021 AT 12:47 PM
L KOPINESS
Thanks that is what I suspected.I replaced the unit about 4 years ago with a lifetime warrenty onr but I cant remember if I got it at orileys or auto zone.
2 LINSEY
  • 287 POSTS
Hi L Kopiness,
Well good luck on getting that warrentied and replaced. We're glad we were able to help and we look forward to helping in the future. Please let us know how it all comes out, and again thank you for using 2CarPros. Com.
