1994 Ford F-150 Air Bag Sensor
1994 FORD F-150
106,000 MILES • 6 CYL • 4WD • AUTOMATIC
BWILLY25
On my 94' F-150 there is a warning light that will blink 3 times then 2 times, and it blinks in the same order and it is the airbag warning light it looks like. I am not sure what I can do or what I need have done on the truck! and will it pass inspection with this warning light flashing?
Nov 2, 2010 at 3:26 AM
WRENCHTECH
  • 20,761 POSTS
Code 32 means "Driver's side air bag module high resistance or open"
That is a problem with the driver's air bag or it's related wiring.
As far as passing inspection, that would be up to the laws in your particular state. I would be surprised if it would be a problem though. Not all cars are equipped with air bags.
Nov 2, 2010 at 3:59 AM
BIGJEFF1987
theres a fuse for it if its bad it will keep blinking
Nov 7, 2010 at 8:45 AM
