This is the 3rd starter I've put in in two weeks, and each time its the same story. So I'm pretty sure its not the starter. I've just replaced the Solenoid and the Ignition switch. No help. When I look inside the Starter area I can see that one area of the flywheel does have some teeth that are a little mangled. Not too bad, but I wonder if they are mangled enough to make the start teeth stick a esecond before disengaging? Is this a real possibility? If so, cant I just file the flywheel teeth a bit to get them in fine shape?
Or, is there another solution or item I can replace? Any good advice is appreciated.
SPONSORED LINKS
Monday, September 27th, 2010 AT 12:34 PM
