1993 Ford F150 oil leak on oil pan
1993 FORD F-150
122,000 MILES • V8 • 2WD • AUTOMATIC
PAULSDOGS
hello, my name is Paul, truck has a 302, truckis on jack stands, engine is raised,motor mounts are loose,exhaust is out of way,inches from getting oil pan out, but cannot get engine high enough to get pan out, help thanks
Sep 9, 2010 at 10:28 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Is the oil pump stopping it from coming out?
Sep 10, 2010 at 6:57 AM
PAULSDOGS
Yes oil pump was stopping it , found out that you drop oil pump should be drop so I did, it si off, okay so it will come out, not so it still hanging up on backside up by transmission, it si loose but will not come out, help thanks
Sep 10, 2010 at 7:06 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Where in the trans is it sticking?
Sep 11, 2010 at 12:34 AM
PAULSDOGS
Hello Bob @ken, the oil pump is out, it is hitting up against transmission cover @ won "t drop past it to come out, I thought motor was high enough for it to drop out the back? help thanks
Sep 11, 2010 at 11:54 AM
  • CERTIFIED EXPERT
  • 110,176 POSTS
If it is still hitting, the only thing that you can do is disconnect the engine and transmission to give you the extra clearance. You may be able to get away with loostening the two.
Sep 12, 2010 at 10:54 PM
PAULSDOGS
Thanks, BOB @ Ken
Sep 20, 2010 at 3:33 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Were you able to get it off?
Sep 21, 2010 at 9:58 PM
