1993 Ford F-150 oil leak on oil pan
PAULSDOGS
  • 1993 FORD F-150
  • V8
  • 122,000 MILES
Hello, my name is Paul, truck has a 302, truckis on jack stands, engine is raised, motor mounts are loose, exhaust is out of way, inches from getting oil pan out, but cannot get engine high enough to get pan out, help thanks
Thursday, September 9th, 2010 AT 10:28 PM
  • 109,885 POSTS
Is the oil pump stopping it from coming out?
Friday, September 10th, 2010 AT 6:57 AM
PAULSDOGS
Yes oil pump was stopping it, found out that you drop oil pump should be drop so I did, it si off, okay so it will come out, not so it still hanging up on backside up by transmission, it si loose but will not come out, help thanks
Friday, September 10th, 2010 AT 7:06 PM
  • 109,885 POSTS
Where in the trans is it sticking?
Saturday, September 11th, 2010 AT 12:34 AM
PAULSDOGS
Hello Bob @ken, the oil pump is out, it is hitting up against transmission cover @ won "t drop past it to come out, I thought motor was high enough for it to drop out the back? Help thanks
Saturday, September 11th, 2010 AT 11:54 AM
  • 109,885 POSTS
If it is still hitting, the only thing that you can do is disconnect the engine and transmission to give you the extra clearance. You may be able to get away with loostening the two.
Sunday, September 12th, 2010 AT 10:54 PM
PAULSDOGS
Thanks, BOB @ Ken
Monday, September 20th, 2010 AT 3:33 PM
  • 109,885 POSTS
Were you able to get it off?
Tuesday, September 21st, 2010 AT 9:58 PM
