1993 Ford F150 Low oil pressure
1993 FORD F-150
163,000 MILES • V8 • 2WD • AUTOMATIC
MLROESER
When I start the truck, the oil pressure does not come back to normal range. There is the proper amount of oil in the truck. I am thinking it could be a bad oil pump or possibly an oil sender switch. Would a dirty oil filter cause high or low oil pressure. I guess that would depend on where the pressure sensing switch comes of the oil line. Any help would be greatly appreciated.
Jan 30, 2010 at 12:37 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
How low is the pressure? Have you ever heard any ticking or knocking from the engine? Also, if there is any concern of the oil filter, I would recommend changing the oil and filter. If you never hear any ticking or knocking, replace the oil sending unit. IF that doesn't take care of it, then I recommend (before removing the oil pan) renting a mechanical gauge to make sure there is a problem. All you do is remove the present oil sending unit and screw in the mechanical one. If you get to this point, let me know so I can help you through it.
If you have other qustions, let me know.
Jan 30, 2010 at 1:53 PM
MLROESER
The oil pressure is off scale low. I havent heard any ticking or knocking so I guess I will do an oil change/fliter replacement and replace the oil sending unit. If that doesnt work then I should check oil pressure with a mechanical gauge. Thanks for your help. If I have any questions I will contact you.
Jan 31, 2010 at 2:01 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
If there isn't noise from the engine, chances are the sending unit is the problem. That is a good thing because the sending unit is cheap.
Let me know what you find and thanks for using 2carpros.com
Feb 1, 2010 at 7:34 PM
