1993 Ford F150 F 150 Engine Vibration while stopped in driv
1993 FORD F-150
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRANK#3
F 150 Engine Vibration while stopped in drive!
My 93 F 150 2 wheel drive, 4.9 liter I-6 engine, C-6 Auto Trans with about 130,000 miles
has gradually over the last several months developed an engine vibration problem when
stopped at red lights, or stop signs with foot on brake, and in drive or reverse.
The vibration is strong enough to be felt through the seat, and can also be seen as the
driver's outside door mirror shakes.
When placed in neutral or park, there is no significant vibration.
During the first 5 minutes of operation (ie when cold) there is no vibration.
My Garage mechanic has changed the plugs, ignition harness, rotor and distributor cap with
no improvement. He has now added a bottle of Injector fluid cleaner to the gas tank.
So far that has not helped either.
I would appreciate any suggestions. You msy email me directly at floch1@rcn.com if you wish.
Frank
Dec 7, 2008 at 8:56 AM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Hi:
Have the trans mounts and engine mounts checked. Many times the rubber on the mount (designed to absorbe vibration) wears out and you feel the vibration through the body of the vehicle.
Let me know what you find.
Dec 12, 2008 at 4:34 PM
FRANK#3
[quote:ac1b71b00f="Jacobandnickolas"]Hi:
Joe[/quote:ac1b71b00f]
Thanks Joe, very much! I'll get those checked out.
Frank
Dec 12, 2008 at 5:59 PM
