Electrical problem
1993 Ford F150 V8 Four Wheel Drive Automatic
how do I get to the pcm on my 1993 f-150 to replace it? Mine is tucked in behind the emergency brake, and without removing the dash I dont see how to get to it.
Thursday, December 11th, 2008 AT 12:01 PM
MECHANIC
Hi:
You will need to remove the e-brake assembly and loosten the dash to get the clearance.
SPONSORED LINKS
Friday, December 12th, 2008 AT 3:27 PM
CHARLIE L
MEMBER
1 POST
Jacoband nickolas
Thank you for your responce, after lookin the situation over a little more, I found that by simply removing the screws from the back half of the inner fender, I could slide it out from the engine compartment side of the firewall. Worked pretty slick.
Again thank you for the help.
