1992 Ford F150 It violently shakes when you hit a bump in t
JASEN3000
Shakes or Wobbles problem
1992 Ford F150 V8 Two Wheel Drive Automatic
My sister in law uses my truck the most and she told me about a shaking problem it had alittle while back. I went and tested it out and when I went alittle fast over a bump it started shaking violently until i let off the gas and slowed down a bit. I took a look under the truck and everything seems to be in place i dont see anything loose. The shake mostly seem to be coming from the bed of the truck, but its hard to tell exactly where.
Aug 14, 2010 at 4:56 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
A visual inspection will not locate worn or loose steering or suspension components, they all need to be physically inspected individually and there are different methods of inspecting the steering & suspension components, if tested incorrectly, a bad item may feel quite sound, so i would strongly suggest that you get a qualified mechanic to do these inspections for you, post his findings here if you wish further assistance with repairs.
mark (mhpautos)
Aug 14, 2010 at 11:23 AM
