1992 Ford F-150 alterantor
DONSTYERS
  • 1992 FORD F-150
  • V8
  • 17,767 MILES
I replace the alt today and a new battery and cerpenteen belt still low volt like 6volt at the batter what could be the proplem the battery light stays onn now didnt befor
Monday, December 15th, 2008 AT 7:14 PM
DAVE H
  • 13,384 POSTS
Check belt tension and all wiring connections >
Alternator Light Stays On With Engine Running
Loose or worn alternator drive belt. Check alternator drive tension and condition,
Loose alternator wiring connections. Check all charging system connections
Short in alternator light wiring
Defective alternator stator or diodes. See Bench Tests in ALTERNATOR article
Defective regulator. See Regulator Check in ALTERNATOR article
Monday, December 15th, 2008 AT 7:59 PM
