Check your EGR valve to see if it is hanging open a little bit. You may have to remove it phisically to see if it is closing. Next, you can do a resistance test on the throttle position sensor, TPS with an ohmeter. With 185K on the truck, it can wear a spot on the coil and creat a "weak" spot. The ECM will usually pick this up and trip the check engine light, but sometimes it won't until the condition gets worse. Hope this helps.
SPONSORED LINKS
Sunday, November 16th, 2008 AT 7:15 PM
