1991 Ford F150 Starting problems sometimes
1991 FORD F-150
50,000 MILES • V8 • 2WD • AUTOMATIC
CHARLESJONES
5.8 liter engine. At home I park on a angle part on the drive and part on the grass so my wife can get out in the morning. I work at nights. The problem started after I changed out the air bypass valve and installed a new fuel filter. I used to be able to turn the key on and the truck would start ok. Now, If I miss hitting the gas when the engine first turns over it takes a long time to get it to start again. It doent matter which tank I have selected either. Once it gets warmed up and I leave it appears to choke a little after leaving a stop sign. Once at work and make the trip home it starts fine. Each time I try to start it I cycle the key off/on to activate the fuel pump again and it takes several tries to get it to start.
Sep 10, 2008 at 10:57 AM
JIMMIEJAMES
i'm having the exact same problem with my f150, even down to the cyclng the key on and off. i was wondering if you ever sourced the problem or not?
Oct 2, 2008 at 8:00 AM
CHARLESJONES
As silly as this may sound the cure was quite basic. I changed the distributor cap and rotor. Added a new fuel filter and stuck in a bottle to clean my injectors. Seemed to work for me. Good luck.
Oct 2, 2008 at 1:59 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
The injector wires can be connected either way.
Feb 3, 2017 at 4:13 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
Please let us know what happens so it will help others
Best, Ken
Feb 6, 2017 at 2:24 AM
