1991 Ford F-150 Boiling Radiator?
XJAZZIE
  • 1991 FORD F-150
  • V8
  • 130,000 MILES
I noticed that after driving for about 30 minutes the water in the reserve was boiling, I have no idea what could be going wrong with it. Also the idle is very high and I am unable to get it to normal, everyone I've asked has no clue on why it does it.
Thnk you in advance :)
Tuesday, July 7th, 2009 AT 8:37 PM
BLACKOP555
  • 10,371 POSTS
Could be related.
The high idle could be caused due to a vaccum leak. Th is will cause it to run lean. A lean running vehicle will run very hot. This can cause it to overheat and boil your water. Check the radiator cap and make sure the fluid is properly mixed.
T-stat could be bad also.
Tuesday, July 28th, 2009 AT 1:11 PM
