1991 Ford F-150
HARR5
  • 1991 FORD F-150
  • 6 CYL
  • 150,000 MILES
Installed a new tiltwheel/turn signal wiring harness- now the turn signals don't work. Could it be a bad harness, or did I forget to do something when installing in steering column. The fuse seems to be good!
Saturday, March 8th, 2008 AT 1:44 PM
BLACKOP555
  • 10,371 POSTS
Since it worked before you changed it and not after, it has probably been installed wrong or the part is no good, go back through and make sure you followed the hookups and directions properly.
Sunday, March 9th, 2008 AT 9:45 AM
