1990 Ford F-150 to much up and down movement in steering column
RON MATTHEWS
  • 1990 FORD F-150
Steering problem
1990 Ford F150 Four Wheel Drive Manual 200'00 miles
how to repair to much up and down movement in the steering column
Friday, December 7th, 2007 AT 9:59 AM
JWALTH02
  • 180 POSTS
Sounds like you need to replace the upper steering collumn bearings. To do that you have to disassemble the steering wheel and upper section, take the lock cylinder out and the steering shaft. You should be able to find the bearings by then. Let me know how it goes. Good Luck.
Friday, December 7th, 2007 AT 5:34 PM
