1990 Ford F150 parts location
160,000 MILES • V8 • 4WD • AUTOMATIC
JPWEIGHTLIFTER81
i was wondering where my fuel filters are located on my truck? it has 2 gas tanks but i only use the rear one. not sure if its in the tank or under the frame or on firewall? also was wondering if my truck has a mass air flow sensor, if so where is it located? the engine is fuel injected.
May 20, 2009 at 3:30 PM
DAVE H
  • 13,383 POSTS
Filters are located inside the tank on the pump assembly and your vehicle is fitted with a MAP (manifold absolute pressure) sensor not a MAF sensor !
https://images.2carpros.com/forum/automotive_pictures/266999_15_2.jpg
May 20, 2009 at 9:53 PM
