1989 Ford F150 motor differences
1989 FORD F-150
KALEB_DUNCAN
Engine Mechanical problem
1989 Ford F150 V8 Two Wheel Drive Automatic xxxxx miles
will a 1993 v8 5.0l bronco motor fit in my 1989 ford f-150
Jul 26, 2010 at 12:53 PM
  • 110,240 POSTS
First, I have to stress we only recommend direct fit parts because there always seems to be some issues when you change things from year to year. Regarding your question, it will bolt right in. However, you will need to change everything over from the old engine to the new one (injection, sensor, vacuum harness, wiring...) Before you even start, closely check the two engine and compare them to make sure everything will work. Again, the engine block should be the same, it is the other things that change over the years that cause problems.
Jul 26, 2010 at 2:49 PM
