HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Drivetrain
Transmission
Gear Selector
SPONSORED LINKS
Transmission leaking
LARRYWAYNE
MEMBER
1989 FORD F-150
6 CYL
2WD
AUTOMATIC
42,000 MILES
Trans is leaking all over exhaust and smoking and delayed gear shift
Tuesday, February 19th, 2008 AT 3:46 PM
BLACKOP555
MECHANIC
Where is it coming from? Tranny cooler lines?
Are you wanting to know how to fix this or what?
SPONSORED LINKS
Tuesday, February 19th, 2008 AT 8:56 PM
LARRYWAYNE
MEMBER
I fixed it. It was the vacuum line. Thanks
Wednesday, February 20th, 2008 AT 5:17 AM
BLACKOP555
MECHANIC
Glad to hear you have found your problem.
Wednesday, February 20th, 2008 AT 7:04 AM
Please
login
or
register
to post a reply.
Related Transmission Gear Selector Content
Shifter Manaul
I Recently Put In A Clutch And Pressure Plate Because I Have A Problem. When I Try To Shift Into High Gear (fourth) It Will Not Go Into...
Asked by
Earlsauto
1 ANSWER
1989
FORD F-150
Stick Shift Is Very Loose Even When In Gear
Recently Had Slave And Master Replaced, Now Stick Shift Is Very Loose Even When In Gear, Wondering If Trans Going Out?
Asked by
medaide63
2 IMAGES
2003
FORD F-150
2001 Ford F150 Transmission Locked Up?
I Have An 01 F150 Truck. Drove It All Day With No Problems. The Next Day I Started It Up Fine And Started Down The Road. About 5 Minutes...
Asked by
josherin
2001
FORD F-150
Transmission Won't Shift
I Just Installed A Rebuilt Engine In My Son's 1996 F-150, Now Transmission Won't Shift Into Any Gear. What Did I Do Wrong?
Asked by
drunge
1996
FORD F-150
1988 Ford F-150 4.9l I-6 5 Speed Manual 132,000miles
I Have A 88 F-150 With A Rebuilt Transmission. Overnite A Problem Developed With My Transmission. When I Shift I Can Find 1st And 2nd Gear...
Asked by
BarefootBob88
1988
FORD F-150
VIEW MORE
SPONSORED LINKS
How to Service a Manual Transmission - EASY!
Topdon OBD2 Scanner Review - This thing rocks
Code Read Retrieval/Clear Mercedes Benz
Online car repair manuals
