1989 Ford F-150 Installing Oil Pump
TPEVEY
  • 1989 FORD F-150
Engine Mechanical problem
1989 Ford F150 V8 Four Wheel Drive Manual
Do I have to pull the motor to install the oil pump?
Tuesday, February 16th, 2010 AT 10:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Have to remove oil pan by removing upper intake manifold, exhaust system and then raise up the engine and remove the transmission crossmember. This will allow replacement of the oil pump.
Tuesday, February 16th, 2010 AT 10:23 AM
TPEVEY
Thank you!
Tuesday, February 16th, 2010 AT 10:33 AM
