HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Starter
Relay
SPONSORED LINKS
1988 Ford F-150 starter relay on fender
BILLBELL
MEMBER
1988 FORD F-150
6 CYL
2WD
MANUAL
190,000 MILES
Need awiring diagram
Tuesday, December 18th, 2007 AT 11:54 AM
JOHNROBERSON
MEMBER
How do you check the continuity of the relay?
SPONSORED LINKS
Wednesday, September 10th, 2008 AT 5:39 PM
JOHNROBERSON
MEMBER
I don't like to use my credit card online, if you will let me know I can send it to you through the mail.
Wednesday, September 10th, 2008 AT 5:43 PM
Please
login
or
register
to post a reply.
Related Starter Relay Content
1983 Ford F150 Starter Relay
Electrical Problem 1983 Ford F150 6 Cyl Two Wheel Drive Automatic Back In Feb. We Had Someone Help Us Jump Our Battery, But They Blew...
Asked by
bdfgrl
1983
FORD F-150
Starter Relay Fuse Burns Out When Ignition Is Engaged
2000 Ford F150 Pickup 4wd 125,000 Miles Is Blowing 15 Amp Breaker When Key Is Turned, Wont Even Engage Starter.
Asked by
pepsiman
FORD F-150
2000 Ford F150 Starter Issues
I'm Lost. I First Began Having Issues With The Truck Not Starting. I Would Get One Click And Nothing. Battery Tested And Is Fine....
Asked by
ffelrod
2000
FORD F-150
1994 Ford F150 New Starter Will Not Spin Engine Over
I Recently Replaced A Sticky Starter With A New One And Now All It Will Do Is Click, The Battery Shows 12.6 Volts, Cleaned And Retightened...
Asked by
brad knight
1 ANSWER
1994
FORD F-150
Starter Replacement?
How Many Bolts Do I Need To Take Off To Remove The Starter?
Asked by
jamesdavis52
31 IMAGES
2004
FORD F-150
VIEW MORE
SPONSORED LINKS
How to Use a Test Light
Starter Motor Replacement
Starter Replacement
Online car repair manuals
