HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Symptoms
Idle High
SPONSORED LINKS
1988 Ford F-150
JIMMY VEAL
MEMBER
1988 FORD F-150
V8
2WD
AUTOMATIC
247,000 MILES
Engine starts&idles high. Stalls&back fires when trying to accelrate
Tuesday, June 15th, 2010 AT 5:12 PM
MECHANIC
Has the check engine light come on? Have you checked for vacuum leaks?
SPONSORED LINKS
Wednesday, June 16th, 2010 AT 10:31 PM
JIMMY VEAL
MEMBER
1 POST
No the check engine light does't come on. I've just noticed the egr is missing. Would that cause my problem? Thanks for your help.
Sunday, June 20th, 2010 AT 9:52 AM
MECHANIC
If the EGR is missing, that wil cause a really bad vacuum leak, so yes, it could be the cause of all your problems.
Let me know what you find.
Monday, June 21st, 2010 AT 12:09 AM
Please
login
or
register
to post a reply.
Related Engine Idle High Content
My Engine Has A High Idle Why?
Changed Plugs And Cops, Truck Ran Great! A Week Later Cleaned Mass Flow, Still Runs Great But, Now Cranks At Extremely High Idle (...
Asked by
Brent basham
15 IMAGES
2006
FORD F-150
2002 Ford F150 Truck Revs Up On Its Own
I Recently Had A Major Tune Up, New Fuel Pump, New Engine And Tranny Mounts. But Now At 35mph It Revs Up By Itself For A Moment. Sometimes...
Asked by
seandoggx
2002
FORD F-150
1994 Ford F150 '94 F150 4.9 Inline 6 Engine High Idle
Engine Problem 1994 Ford F150 Four Wheel Drive Manual 153000 Miles I've Got 153,000 Miles On My Truck, Its 4wheel Dirve With A...
Asked by
hoss87
1994
FORD F-150
1991 F150 High Idle
The 1991 F150 (v8-5.0l, 2wd, Aod Transmission) I Gave To My Son In October 2005 Has Idled Way Too High Since I Got The Transmission...
Asked by
golf-nut
1991
FORD F-150
1995 Ford F-150 Constant High Idle
Cannot Get Engine To Reduce Rpm's. When I Put It In Drive, It Still Goes 15-20 Mph Down The Street! Replaced The Tps, Iac Valve And 02...
Asked by
rxonfire
1995
FORD F-150
VIEW MORE
SPONSORED LINKS
Vacuum Leak Symptoms
Vacuum Leak
Vacuum Leak Test and Repair
Online car repair manuals
