1987 Ford F150 the doosy
1987 FORD F-150
357,985 MILES • 6 CYL • 2WD • MANUAL
TRAVIS BRENTON
okay so I have an '85 f-150 (Carborated) and an '87 f-150 (EFI) I want to switch engines i have heard that it is possible but not probable lots of electrical work would like to know anything that can help to make it a faster smoother job with less cussing if you know what i mean
Jul 9, 2008 at 11:03 AM
BLACKOP555
  • 10,386 POSTS
you putting the carb in the efi vehicle or the efi engine in the carb vehicle?
Jul 10, 2008 at 1:40 AM
TRAVIS BRENTON
I am acctually attempting to switch the engines entirerly 87 gets the carb and 85 gets the EFI I have heard that the EFI has a whole lot more electrical then the carb thus making it harder but I dont care about that i will have time
Jul 10, 2008 at 2:46 AM
BLACKOP555
  • 10,386 POSTS
for efi you will have to have a low pressure in tank pump and a high pressure in line pump in order to get it the fuel it needs and yes the electrical is more then the carb but it isnt too much more copmlicated, you will need to transfer just about all of the electrical components..
for the carb you can eliminate the inline pump and you should be able to hook it up and run it, you may have to have a fuel pressure and volume reducer though.
Jul 10, 2008 at 11:04 AM
