updated 1/15/10
I am planning to get the truck inside this week as there is a lot of snow on the ground around here. I will go over the grounds with a fine tooth comb. Do you know of any diagrams that have the ground locations on them. I have a Haynes manual and it has wiring diagrams but there is no mention of where they are. I noticed today when the engine died after opening the hood that the wiring harness that has the plug that connects the ignition module has been soldered together as if the plug was replaced or something. I will check that out too. Another thing I noticed today was that after cranking the motor with the transmission in neutral trying to restart it after it died that it did not start until I put the tranny in first gear! Any ideas about that. It seems that it only stalls agter the moter has warmed up and I have driven it ten or fifteen miles. I have wiggled the ignition switch when the engine misses and it has no effect. I am wondering about the ECM control relay, and also the fuel pump relay. Is there a separate relay for the high pressure pump? I appreciate any light you may be able to shed on this intermittent problem. I have spent a lot of doe replacing things that did, nt need to be replaced. There are no trouble codes showing up. Thanks for your time Mike.
Sincerely, Bob
SPONSORED LINKS
Sunday, January 10th, 2010 AT 4:19 AM
