1987 Ford F-150
DON33
  • 1987 FORD F-150
  • 6 CYL
  • 87,000 MILES
Engine starts fine idles fine but when I put in gear (automatic) it wants to die sometimes does but when doesnt die it runs fine. Put new fuel pump and filter, new transmission filter and fluid. Air filter new any ideas
Sunday, May 2nd, 2010 AT 6:29 PM
  • 109,896 POSTS
Have you checked for vacuum leaks? Also, how high is it idleing in park?
Monday, May 10th, 2010 AT 10:43 AM
DON33
  • 11 POSTS
No have not checked for vacuum leaks. Idle is at 900 rpms when warm and in park. What should it be?
Friday, May 14th, 2010 AT 4:05 PM
  • 109,896 POSTS
Actually between 700 and 900 is good. Check to see if you can find any leaks. With the engine running, listen for hissing sounds that may indicate there is a leak.
Let me know what you find.
Saturday, May 15th, 2010 AT 11:03 PM
