1986 Ford F-150 truck spits and sputters and dies after warm
BIGD81569
  • 1986 FORD F-150
Engine Performance problem
1986 Ford F150 V8 Two Wheel Drive
My 86 F-150 truck runs great until it warms up and then you can't press down the gas. It wil start sputtering and then bog down and die. Now for the first 20 mint. Or so it runs great, then as soon as it gets warmed up or a lil hot is when it starts acting up.
Sunday, June 8th, 2008 AT 9:03 AM
MERLIN2021
  • 17,250 POSTS
Check engine light come on? Could be an EGR or EVR problem, EGR is not used during engine warm up...test for codes! Same applies to heated 02 sensors...
https://www.2carpros.com/forum/automotive_pictures/62217_Test_Connector_Pre96_15.jpg
do this and count the flashes...Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 11 or 111. Write them down and post here. First do this with the ke on engine off, then again with it running.
Sunday, June 8th, 2008 AT 9:22 AM
DUEYCRAVEN1
  • 5 POSTS
Having similar problem with my '85 302 EFI. Did you ever figure what was going on with yours?
Tuesday, July 1st, 2008 AT 9:52 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Check your Coolant Temp Sensor. Or just replace it, it is not very expensive. In my experience I find that this sensor will very seldom give code unless Not Working at all.
Tuesday, July 1st, 2008 AT 10:28 PM
