HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Oil Pump
Replace/Remove
1985 Ford F-150 oil pump
CHIP1203
MEMBER
1985 FORD F-150
Engine Mechanical problem
1985 Ford F150 V8 Two Wheel Drive Automatic
how to replace the oil pump
Sunday, April 5th, 2009 AT 6:09 PM
CHIP1203
MEMBER
Sunday, April 5th, 2009 AT 6:19 PM
DOCFIXIT
MECHANIC
Need to pull the oil pan off. That requires loosening motror mounts raiiseing engine
Sunday, April 5th, 2009 AT 6:30 PM
Please
login
or
register
to post a reply.
Related Oil Pump Replace/Remove Content
Oil Pump Replacement Instructions
Do You Have Any Diagrams For How To Change The Oil Pump?
Asked by
ronnieirby
1 ANSWER
31 IMAGES
2003
FORD F-150
2002 Ford F150 Changing Oil Pump
If My Oil Gauge Goes From The Middle Of The Gage To Low Causeing My Oil Light To Come On Only When I Come To A Stop But Comes Right Back Up...
Asked by
jrvalflores
1 ANSWER
2002
FORD F-150
2001 Ford F150 Change Oil Pump
Engine Mechanical Problem 2001 Ford F150 V8 Two Wheel Drive Automatic I Have A Ford F-150 In Wich The Oil Pump Stoped Working. The...
Asked by
teko02
1 ANSWER
2001
FORD F-150
Oil Pump
Replace Oil Pump How Can I Replacet0he Oil Pump In My 97 Ford 150 8 Cl 4.6
Asked by
latinboy2727
1 ANSWER
5 IMAGES
1997
FORD F-150
I Keep Losing Oil Pressure?
I Keep Losing Oil Pressure At Startup On Cold Days I Can Rev The Truck To Around 2500 Rpm And The Oil Pressure Will Come Up If I Let Off The...
Asked by
tslonecassie
1 ANSWER
1 IMAGE
2001
FORD F-150
VIEW MORE
Engine Oil Change and Filter GMC
Engine Oil Change and Filter Replacement
Engine Oil Change and Filter Mercedes
