1994 Ford F-100 serpentine belt
130,000 MILES • V8 • 4WD • MANUAL
CLIPMONK
1994 ford f150 v8 5.0 the belt wont stay on the crank or engine pulley. it jumps one groove off towards the fan. so im on my 2nd belt in the past 2 months. i replaced the idler pulley, and water pump so far. all the other pulleys are fine but the power steering pulley "which is plastic" it has a few chips out of some of the grooves. im pretty sure thats not the problem tho cause the belt goes around the water pump bell before it goes on the crank pulley. if u look at a diagram u'll see what i mean. so it rides fine on all the pulleys but the crank pulley.
Jul 30, 2010 at 9:20 PM
  • 31,937 POSTS
Hi there,
This will be an alignment problem, some work shops have hand held laser aligners checkers, you may need to do this to find out which pulley is causing you the problem.
mark (mhpautos)
Jul 30, 2010 at 9:23 PM
