Replaced the battery, starter/solenoid, and alternator, all were bad. The old alternator had bad bearings and the battery was just old. The car simply did not start and still wont. Accessories work, however only the solenoid clicks over, not the engine what so ever. The fly wheel is ok. Could it be the ignition coil, crankshaft sensor, or a faulty ground?
SPONSORED LINKS
Sunday, July 8th, 2007 AT 10:30 AM
