Gurgling sound at the gas tank
BGINN
  • FORD EXPLORER
I have a 1998 Ford Explorer Sport XLT AWD with a 5.0L engine. Milage is 130,000.
There is a gurggle / bubbling noise when the ignition key is turned to the first notch (or beyond). It happens when the car is both cold or hot. The car seems to run OK, but this is a new noise and I would like to know if it may be an indication of something going wrong.
It sounds like it is comming from the fuel tank.
What could cause this kind of noise.
Monday, July 9th, 2007 AT 1:12 AM
MERLIN2021
  • 17,250 POSTS
The fuel pump! It's in the gas tank.
Monday, July 9th, 2007 AT 7:28 AM
BGINN
Thanks merlin2021,
Does the sound mean that the fuel pump is getting ready to fail, or is there something I can do to prevent the failure?
Bginn
Monday, July 9th, 2007 AT 10:00 AM
