1996 Ford Explorer Cylinder 3 Misfire
VALLEY_MAN0505
96 Ford Explorer (4WD); 120,000 miles--A while ago, the CEL came on and the code was for a misfire in two cylinders. I don't remember both cylinder numbers, but one of them was the #3. Ran fuel injector cleaner and replaced all spark plugs and plug wires. Ran fine for about 2 months, but CEL just came on again. This time, only one cylinder misfired and it was the #3 again. Since another cylinder misfired along with the #3 last time, it is difficult to say if the problem is specific only to #3 or if it just coincidence that #3 was involved both times. Engine does sometimes (not always) sputter and sometimes almost die upon starting it, but typically not noticeable problems once started. Something else that also may be a coincidence but the 2 times this happened happened to be the 2 hottest days of the summer--don't see how temp would affect a cold start, though. Also, it seems that this vehicle has always gotten poor fuel mileage (15-16 mpg with mostly highway miles). Have only had this vehicle for 9 months now, so not sure on past problems. Also, soon after buying, the O2 sensors crapped out--both were replaced along with catalytic converters under the dealership warranty since this happened within 30 days of purchase. Well, that is a ton of info--hope someone can decipher it. I have come across a ton of different potential causes, but don't know where to start and don't want to to trial-and-error if I don't have to. Leaning towards some type of EGR related problem so far, but I am obviously open to advice.
Aug 14, 2007 at 3:21 PM
  • 75,988 POSTS
[quote:85ebf13b69="valley_man0505"]96 Ford Explorer (4WD); 120,000 miles--A while ago, the CEL came on and the code was for a misfire in two cylinders. I don't remember both cylinder numbers, but one of them was the #3. Ran fuel injector cleaner and replaced all spark plugs and plug wires. Ran fine for about 2 months, but CEL just came on again. This time, only one cylinder misfired and it was the #3 again. Since another cylinder misfired along with the #3 last time, it is difficult to say if the problem is specific only to #3 or if it just coincidence that #3 was involved both times. Engine does sometimes (not always) sputter and sometimes almost die upon starting it, but typically not noticeable problems once started. Something else that also may be a coincidence but the 2 times this happened happened to be the 2 hottest days of the summer--don't see how temp would affect a cold start, though. Also, it seems that this vehicle has always gotten poor fuel mileage (15-16 mpg with mostly highway miles). Have only had this vehicle for 9 months now, so not sure on past problems. Also, soon after buying, the O2 sensors crapped out--both were replaced along with catalytic converters under the dealership warranty since this happened within 30 days of purchase. Well, that is a ton of info--hope someone can decipher it. I have come across a ton of different potential causes, but don't know where to start and don't want to to trial-and-error if I don't have to. Leaning towards some type of EGR related problem so far, but I am obviously open to advice.[/quote:85ebf13b69]
Could be a lean fuel mix or a weak spark- Vacuum leak in the intake manifold and unmetered air behind the throttle body no being measured by airflow sensor/burn exhaust valve/EGR problem/injector on no.3
Low fuel pressure and bad gas.
Random misfire is normally caused by vacuum leaks and bad gas.
Aug 14, 2007 at 3:59 PM
Suggested Repair
Check for a lean mixture or weak spark on cylinder 3. Inspect for an intake vacuum leak or unmetered air, low fuel pressure, bad fuel, a faulty cylinder 3 injector, an EGR problem, and a burned exhaust valve.
Conversation Summary
A 1996 Ford Explorer with 120,000 miles has a recurring cylinder 3 misfire after plugs and wires were replaced and injector cleaner was used. It sometimes sputters or nearly dies on startup, gets poor mileage, and previously had oxygen sensors and catalytic converters replaced. The expert says the cause may be a lean mixture or weak spark, including a vacuum leak, unmetered air, low fuel pressure, bad fuel, a cylinder 3 injector, an EGR problem, or a burned exhaust valve.
