Ford Explorer 97
RKESBIA
I have Ford explorer 97. Can you tell me what the following results means? I used ScanTool:
Long Term Fuel Trim (Bank 1) -100%
Short Term Fuel Trim (Bank 1) -100%
Long Term Fuel Trim (Bank 2) -100%
Short Term Fuel Trim (Bank 2) -100%
Thanks
May 2, 2006 at 1:02 PM
RKESBIA
Well! That what I found. Welcome to any one who can add more information Thank.
The fuel trim, both long-term and short-term, refers to the changes the ECU is making to the fuel delivery. Severe negative fuel trim indicates
that the ECU is commanding the fuel delivery lean, presumably to compensate for a rich runing condition. Without getting into excessive
detail, the most significant aspect of severe negative fuel trim is that the ECU knows there is a rich condition, and is attempting to correct
it, as opposed to a rich condition commanded by the ECU. With the ECU
attempting to correct for a rich condition, you should suspect mechanical component failures, such as fuel injectors, fuel pressure regulators, etc., as opposed to sensor failures such as bad O2 Sensors,
Temperature Sensors, etc..
May 11, 2006 at 1:23 PM
