1999 Ford Explorer Air Suspension
LEV1017
1999 Explorer XLT 5.0L w/towing package - approx. 56,000 miles. Automatic Air Suspension load leveling worked fine until about a couple of months ago (used to be a little annoying when I'd get in and I'd hear the air pump engage to re-level the vehicle!) I checked the ON/OFF switch connection in the back and cycled it a few times, still no action. The "Check Air Suspension" light does illuminate upon startup, then goes off, as it always has. Anything else I can check before taking it in to dealership? Thanks!
May 7, 2007 at 10:30 AM
MERLIN2021
  • 17,250 POSTS
Check fude and relay in power distribution box under the hood...then listen for air leaks if the compressor runs...if it runs all the time tow the car and fix it...it will burn out the pump..then you are F____K_ED
May 7, 2007 at 12:26 PM
Suggested Repair
Check the fuse and relay in the power distribution box under the hood. If the compressor runs, listen for air leaks. If it runs continuously, tow the vehicle and repair it promptly so the pump does not burn out.
Conversation Summary
The owner of a 1999 Ford Explorer XLT said the automatic air suspension load leveling stopped working a couple of months ago. The check air suspension light still comes on at startup and then goes off, and cycling the rear on/off switch did not restore operation. The expert advised checking the underhood fuse and relay, listening for air leaks if the compressor runs, and towing the vehicle for repair if the compressor runs continuously so the pump does not burn out.
