I know this was posted a while back so it's probably fixed by now. But the problem is likely the wheel bearings.
The wheel bearings will be inside the brake rotors. There is an inner and outer bearing in each. (The outer bearing is accessible without removing the rotor)
You can easily replace the bearings. Remember to replace the seal holding the inner bearings in place also.
SPONSORED LINKS
Saturday, September 15th, 2007 AT 4:34 PM
