2003 Ford Explorer Dead Battery
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
PETER CRAIG
Battery keeps going dead, when it has not been running for a day or so.checked alternator it is putting out 14volts when running
Mar 22, 2008 at 11:22 PM
SERVICE WRITER
  • 9,123 POSTS
There may be a parasitic draw on the battery. Check the draw on the battery, should be less than 30 milliamps. IF it is above that pull a fuse one at a time to naroow down the circuit that is the drawing circuit. Once you establish the circuit first check the obvious like a switch that is on.
Are you haveing any problem with the domw light staying on? The fords are notorious for the latches getting sticky and leaving the ciruit active to the dome light. Light lube soak will usually fix that.
Mar 22, 2008 at 11:48 PM
