If you are hearing grinding noises, if you know how to inspect brakes, do that, if not tow it to a qualified repair shop. GRINDING mean there is no more brake lining material left on the pads. you are nor riding metal on metal, and worn so far down that the caliper is probably loosing brake fluid as well, TOW to a shop!
Mar 13, 2010 at 1:04 AM
