2002 Ford Explorer spark plugs and coils
RUSS815
  • 2002 FORD EXPLORER
Engine Performance problem
2002 Ford Explorer V8 Four Wheel Drive Automatic
how do you cange spark plugs and coils on a 2002 explorer v-8
Saturday, April 3rd, 2010 AT 2:48 PM
  • 109,772 POSTS
Do you have a coil for each cylender? If so, there is one bolt that holds the coil on. Remove it and using a plug socket and extension, remove the plug. Don't replace the coils unless you are sure they are bad. They usually last a long time and are expensive.
Sunday, April 4th, 2010 AT 12:25 AM
