2002 Ford Explorer heater control
2002 FORD EXPLORER
95,000 MILES • V8 • 4WD • AUTOMATIC
FRANK CORNISH
heat comes out on dash one day floor next day defroster next day or where it wants to control does not matter what setting it is on
Mar 14, 2010 at 10:05 AM
  • 110,240 POSTS
I think you are looking for a vacuum leak. The vent doors are actuated by vacuum. If there isn't enough or none, then they won't work properly. Check under the dash for leaks. Also, with the engine running, you may get lucky and hear a hissing sound from where there is a problem.
Check that out and let me know what you find.
Mar 15, 2010 at 3:44 AM
