2002 Ford Explorer Air Conditioner vents
76,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRANDONKELLY
When I run the A/C in the city, it works fine. But when I throttle up on the expressways the forward vents turn off when I exceed 50 MPH. Air stops flowing from the forward facing vents but still comes out the floor and window vents. What would cause this?
May 25, 2010 at 11:18 AM
  • 110,251 POSTS
In this case, you are looking for a vacuum leak. THe vents are actuated by vacuum. When you accellerate, the engine vacuum drops. If you have a leak, the direction of the vents will change.
Check under the dash and the hood for leaks. With the engine on, you may get lucky and hear a hissiing sound.
Let me know what you find.
May 25, 2010 at 11:31 PM
