2002 Ford Explorer 4x4
115,098 MILES • 6 CYL • 4WD • AUTOMATIC
TBOSSMAN3
my 4 wheel drive does not work 4x4 high low light flashes
Feb 28, 2009 at 11:28 PM
MERLIN2021
  • 17,250 POSTS
Have the truck scanned for "B" codes, generic scanners dont read these, so a shop or Ford needs to scan it, this will give you the defective paithout the guesswork. The starting point is tires, they must be exactly the same size, this means same manufacturer ansd same series! Air pressures need to be the same too!
Feb 28, 2009 at 11:48 PM
