2002 Ford Explorer
ASIMILY
  • 2002 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 98,962 MILES
My air conditioning has started to blow hot air. I have had the refridgerant checked and am told it is full. What could be wrong?
Tuesday, July 8th, 2008 AT 3:54 PM
KHLOW2008
  • 41,814 POSTS
Hi asimily,
There are so many possible reasons.
Did you check if the compressor was working?
If it is working, you need to check the low and high pressure, post the readings here and help should be on the way.
Wednesday, July 9th, 2008 AT 9:51 AM
