2002 Ford Explorer
ELABIANCA
  • 2002 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 105,000 MILES
Replace the left rear window motor and regulator
Thursday, May 27th, 2010 AT 11:47 PM
  • 109,885 POSTS
To remove the motor, you need to remove the door panel to access the motor. The motor will be rivited into place. Drill out the rivits, remove the motor, replace it and replace the motor with nuts and bolts. Make sure there is clearance between the bolts and glass when the window is down.
Friday, May 28th, 2010 AT 1:35 PM
