HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Engine
Symptoms
Overheat
SPONSORED LINKS
2000 Ford Explorer OVERHEATING
JRBRYANT
MEMBER
2000 FORD EXPLORER
Engine Cooling problem
2000 Ford Explorer 6 cyl Two Wheel Drive Automatic
WITH CAR COOL I ADD WATER AND AS IT HEATS UP THE WATER BLOWS OUT OF RADIATOR. THE CAP HAS NOT BEEN INSTALLED YET.
Wednesday, January 28th, 2009 AT 4:48 PM
MECHANIC
Get it block and pressure tested-sounds like a blown headgasket
SPONSORED LINKS
Wednesday, January 28th, 2009 AT 4:56 PM
JRBRYANT
MEMBER
I JUST PAID A GUY $1600 TO REPLACE THE HEAD GASKET AND HE REPLACED A HEAD. YOU THINK THE GASKET IS STILL BLOWN?
Wednesday, January 28th, 2009 AT 5:00 PM
MECHANIC
To find out get it block and pressure tested just did a car the other day doing the same thing-Headgasket leak-verify it
Wednesday, January 28th, 2009 AT 5:02 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
2000 Ford Explorer Oil And Over Heating
What Type Of Oil Should I Be Putting In My Ford Explorer Sport. All Of A Sudden, It Is Over Heating And I Noticed The Oil Was Almost 2 Qts...
Asked by
JBarstow
1 ANSWER
2000
FORD EXPLORER
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
2000 Ford Explorer
Engine Cooling Problem 2000 Ford Explorer 6 Cyl Two Wheel Drive Automatic I Can Drive My Vehicle Around With The Air Running And It...
Asked by
AmberEPow
2000
FORD EXPLORER
Overheating
My Temperature Gauge Is Reading Hot. I Have Flushed The Radiator, Put On A New Water Pump, And, Changed The Housing And Thermostat. Do...
Asked by
Ijohnson2
1999
FORD EXPLORER
Engine Overheating
Temperature Gauge Reaches The H Level When I Drive One Hundred Miles The Engine Becomes Very Hot And Stopped On The Road The Vapor Goes Out...
Asked by
mahdobeid
2005
FORD EXPLORER
Engine Overheating
My Problem Happens Spiraticaly. Some Days No Problems And Other Days My Car Tends To Overheat. I Have Replaced The Thermostat And Had...
Asked by
lcaffee
2004
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Coolant Leak Symptoms
Online car repair manuals
