2000 Ford Explorer oil pressure
BRIAN18980
Engine Mechanical problem
2000 Ford Explorer 6 cyl All Wheel Drive Automatic
when i am driving it after i few min it looses oil pressure. could it be the oil pump
Nov 17, 2009 at 1:04 PM
RICKMAR
  • 170 POSTS
Hi Brian;
When you first start the engine is the oil pressure reading o.k.?
When you are driving it for a few minutes and you suddenly lose oil pressure, does the oil pressure gauge eventually show pressure again?
If the answers are "YES" to the two questions above. I would say the problem is a malfunctioning oil pressure sender.
When you drive the vehicle and the pressure gauge drops. Pull over and just let the engine idle.
If you do not hear any clattering/clicking sound or loud tappet noise after a brief period of letting the engine idle.
I would say you have a bad oil pressure sender.
If you do hear unusual noises shut the engine off "Immediately"
Hearing clicking/clattering or loud tappet noise , you have a bad oil pump because the engines moving parts are not receiving oil.
Good Luck;
Rick
Rick
Nov 18, 2009 at 8:41 AM
