2000 Ford Explorer horn fuse
VPENA
Noises problem
2000 Ford Explorer 6 cyl Four Wheel Drive Automatic
As soon as I replace my horn relay fuse and try the horn it blows out - Why?
Apr 14, 2009 at 8:03 AM
MERLIN2021
  • 17,250 POSTS
Can be the horn itself is bad, or the switch, or wires that connect it all...unplug the horn and re try it leaving horn disconnected, then if you can use a test light on the horn wire, hit the button, does the light light? If it blows without the horn by hitting the button, then it's usually the button.
Apr 14, 2009 at 8:43 AM
