Lets take these problems one at a time.
Could you be more specific with this? Is the car shaking, swaying, vibrating, or is there a growning sound or do you mean you hear something shiking?
Need a better description of this as well; mainly, there is a lot of stuff toward the front of any car. You need to open up the hood and listen carefully and try to get a better idea of where the sound is comeing from. As you look at the fron of your car, which side of the engine compartment does the sound seem to be comeing from, is it toward the top of the engine or closer to the ground, is the ratteling constant or intermittent?
First off, how long ago were the air filter, fuel filter, spark plugs, and egr valve replaced?
Is your computor throwing any trouble codes?
SPONSORED LINKS
Tuesday, February 20th, 2007 AT 5:27 PM
